Euh.............. MALADE 8)
Le fait de ne pas avoir de moto à moi, ne me prive pas de cette passion...
Motodirect.net là où la passion nous unit ...
[smilie=eeksmilie.gif] j'voudrais pas voir la vitesse max de cette chose la [smilie=sprint] ou bien encore l'acceleration... :shock:
alors, meme dodge n'a que des estimations de la vitesse de cette fusée...
avis aux intéressés
500 bhp (373 kW) @ 5600 rpm (45 kW/L); 525 ft·lbf (712 Nm) @ 4200 rpm
10-cylinder 90-degree V-type, liquid-cooled, 505 in³ (8275 cc)
356-T6 aluminum alloy block with cast-iron liners, aluminum alloy cylinder heads
Bore x Stroke: 4.03 by 3.96 in (102 x 101 mm)
Two pushrod-actuated overhead valves per cylinder with roller-type hydraulic lifters
Sequential, multi-port electronic fuel injection with individual runners
Compression Ratio: 9.6:1
Max Engine Speed: 6000 rpm
Fuel Requirement: Unleaded premium, 93 octane (R+M/2)
Oil System: Dry Sump; takes 8 quarts (8 L) Mobil1 10W30 Synthetic
Cooling System: Twin aluminum radiators mounted atop engine intake manifolds, force-fed from front-mounted, belt-driven turbine fan. Takes 11 quarts (10 L) of antifreeze.
Exhaust System: Equal-length tubular stainless steel headers with dual collectors and central rear
According to the official specs 0-60 mph times have been estimated at 2.5 seconds, with a top speed of 300+ mph. But there are also reports that the top speed is 676 km/h (about 450 mph).
